How to remove rear seats in 02 Accord
My son lost a lego part through the opening for the seat belts in the bottom part of the back seat of my accord. If I try to pull up the back seat on the lower back of it on the right and left sides, I can tell those portions come up easily. Apparently, there is something in the middle holding the seat down. Would appreciate any advice I can get as to removing the back seat.
Thanks, JD |
The picture is for a 4-door, you didn't say...
http://www.hondaautomotiveparts.com/...3s8411_b41.png Feel in the crack between the seat base & seat back. You're looking for the bolt #30. (probably use a 10mm socket?) It's not dead-center, it's towards the left (drivers) side of the car. See the little tab sticking up from the seat base in the picture. Remove that one bolt; then the seat base can slide a bit forward & unhook the forward edge. |
How to remove rear seats in 02 accord?
Jim,
Thanks a lot. Will give it a try. By the way, I grew up in Cleveland, lived in Columbus for a long time, and am currently in Cincinnati. Best wishes, JD |
I was just down there. My wife ran 10k in the Flying Pig.
Picture?
Originally Posted by JimBlake
(Post 204062)
That's been so long ago that Majestic Honda probably changed around their site.
Go to www(dot)hondaautomotiveparts(dot)com Or www(dot)hondapartsnow(dot)com (Or your favorite on-line parts store probably uses the same pictures from Honda's electronic parts catalog) Click "parts". Enter your car's information. Pick the category that has seats & interior or something like that. |
or see this - don't let the title throw you off.
Plus it would help to know if your car is a two or four door. https://www.hondaaccordforum.com/for...removal-59143/ |
