Ventilation Fan Noise 2009 Accord
Hey everyone. New to the forum and have found lots of useful info for my '09 Accord. Just thought I'd share a problem I had with my car recently that others may be experiencing.
I started noticing the blower fan for the HVAC system made a constant high pitched pulsating noise coming from under/behind the glove box. Not super loud but really annoying especially if you like to drive w/o the radio from time to time. It is more noticable when fan speeds are low b/c you can't hear the air blowing from the vents. When you turn the system off it stops, so clearly its a blower motor issue. Took it to the dealer and they replaced the blower motor... no help, still makes noise. Then I found out on another forum out there that the EXL v6 with NAV has a shroud called the "lower passenger cover" (Part Number 77346-TA6-A01) that snaps into place under the glove box. This is the only trim level that gets this part. All others have the mounting/snap points but they don't install it at the factory for some reason. It has sound deadening material on the back of it and everything. Bought the part for $25, took 30 seconds to snap into place and the sound is gone completely. I'm suprised Honda would not include this part on all cars. Clearly they are aware of the noise issue if they designed a purpose built part to mask it. Suprising they would put there reliability/refinement reputation on the line for such a cheap part. I doubt anyone would bat an eye if their $25,000 Accord was all of a sudden $25,025. Just thought I'd share my small but annoying problem that others may have. I'd have to believe the noise is "normal" and that all cars have this noise considering they replaced the motor and it still made the noise. Perhaps others out there have the same issue. Good luck, hope this helps! |
Welcome newbie!
First post after joining & it's nice and informative. I think I'm gonna move this into the DIY area. |
We just bought a pre owned 2009 Accord LX last night! I did notice the noise when I turned the heat on ....the exact noise you mentioned....so thanks..we will look into that part. We are also hearing a loud engine noise though....like a loud whining noise...it didn't seem too bad at the dealer...although we did notice it and thought it was just normal....but this morning I went to start it and it sounds louder!!! Is that something normal in a 2009 model...when I google it ...it does come up. Just to note when I turned the heat off...I still can hear loud engine noise....when I turn the heat back on ...I hear both noises!! I just need advice...because it is certified and we have a 12,000 mile warranty...so if the engine noise isn't common or normal...I will take it in to have it looked at.
Thanks |
ventilation fan
Originally Posted by msherman03
(Post 185451)
See service bulletin:
Honda TSB 09-093 Note: Technical service bulletins are not recalls, unless specifically noted as related to a recall; generally, they are to help Honda technicians with known issues. Issues noted in TSBs do not necessary apply to all vehicles. Normal warranty applies. |
(Post 353748)
It is easy and can be done in less than a minute. Once you get the part, you'll see the tabs, line them up with the holders and everything snaps into place.
(Post 353789)
