"Accord Swap"
Hi, does anyone know all the parts I need to do a complete swap for my 92 honda accord?
I plan to put a 94-95 accord ex v-tec engine in my 92 accord. I'd be very thankful for any info because I haven't found any info on this swap. My guess is just direct fit with a v-tec ecu. What else do I have to do if the new motor is automatic and my car is a manual? |
RE: "Accord Swap"
i recomment that u go and get the ecu that u r getting the motor form and if the motor u are getting u can always swap out the auto transmisson with ur manual transimission
RE: "Accord Swap"
yah dont do it not onlywill it cost you more than buying a newer car but to go from auto to man as well?? not worth it. this will take more effort, money, and time than it would be worth
RE: "Accord Swap"
Just turbo your 92 Accord. The block should be able to take it (up to 8-10 psi of boost).
That beats any ol' swap. You only gain so much (+10?). EDIT- Plus you have a manual....:D |
RE: "Accord Swap"
also if u swap the motor u have to also get motor mounts fomr the motor u are swapping
RE: "Accord Swap"
Drop an H22 in there!!
RE: "Accord Swap"
^ Yep.
RE: "Accord Swap"
well im not a mechanic but iknow you need a gasket set for the whole engine
and your motor isnt automatic your tranny is you need a manuel tranny or keep it and convert your car to automatic but i dont know why you you wanna do that and its 10 times more of a pain in the rear so you need a new tranny and yeah im sure theres more to it than that thats just what i know |
RE: "Accord Swap"
ORIGINAL: accordbeatsintegras Hi, does anyone know all the parts I need to do a complete swap for my 92 honda accord? I plan to put a 94-95 accord ex v-tec engine in my 92 accord. I'd be very thankful for any info because I haven't found any info on this swap. My guess is just direct fit with a v-tec ecu. What else do I have to do if the new motor is automatic and my car is a manual? You don't have to do anything if the motor came from an auto. It makes no difference. |
RE: "Accord Swap"
Yes do an H22..it is literally a direct fit except needing the rear prelude engine mount and the preludes passenger side axle.
Go to www.cb7tuner.com for complete info on motor swaps for the 90-93 accords |
