**Throttle Plate Loose...Help**
98 Accord Ex 2.3
Does anyone know if the throttle plate on my car is adjustable? I just found out that my plate is not closing tight and is leaking some air in. I already clean it with some cleaner. Any comment is appreciated.... |
RE: **Throttle Plate Loose...Help**
there is a tsb on it but I do not know who is hosting it........DesertHonda should be about help you on that specific one
there is a bulletin # 01-004. jan 9 2001......
but that is for the throttle plate sticking,, all you do is partially remove the throttle plate and clean it on both sides normal warranty applies 3 yrs 36k miles |
ORIGINAL: 98accord98 98 Accord Ex 2.3 Does anyone know if the throttle plate on my car is adjustable? I just found out that my plate is not closing tight and is leaking some air in. I already clean it with some cleaner. Any comment is appreciated.... |
is there a way to remove the throttle plate without removing the whole throttle body?
yes, the throttle cable is properly adjusted. |
are you able to push the throttle plate closed without any trouble? because if that were off, that would mean the tps is off and you would be getting a cel code, second did you check to see if the two mounting screws were tight?
i cant remember if those were on the inside or the outside but the throttle body is easy to remove either way.... youll just most likely need to buy another gasket for it and yes you would have to take off the tps, and that is riveted on there otherwise a new tps/throttle body is like 240$ give or take |
marbro
thanks for the reply. i notice that my idle went down a little to about 800rpm when i push on the plate. so this makes me think the plate is loose. the idle is already adjusted to the min. and is sitting at about 900 to 1000rpm, which is a little high. the engine did not throw the cel light. this throttle body has never been removed before so i don't think it's the mounting screw........i am kinda thinking just buy a new throtle body. |
