Subframe removal
Old 07-27-2007, 02:07 PM
mck52689's Avatar
Default Subframe removal
Im not a genius when it comes to accords but i need to remove the sub frame.... what will happen if i take it off, or move it for a few minutes time.
Old 07-27-2007, 06:28 PM
Default RE: Subframe removal
Subframe?Accords are unibody construction....so what piece are you talking about?
Old 07-27-2007, 07:21 PM
deserthonda's Avatar
frt beam ?
rear beam ? where the p/s rack is mounted ??
Old 06-14-2012, 04:19 PM
Question Subframe removal-HELP!
I am going to have to replace the rack and pinion as well as the subframe where the bracket that holds it in place on the drivers side, the bolt sheard off from the subframe and now is loose. Any input is greatly appreciated!
2003 Honda Accord EX
Old 04-11-2018, 02:37 PM
I'd like too jump in here and ask a question. Im getting ready to swap out my engine on my 99 honda accord (v6 vtec) I've been told that there isn't enough room for just the engine to cone out the top and to just drop the engine and trans together from bottom. In your comment to someone else you said the frame is unibody. Someone told me you need to remove subframe or k frame? You have any info that will help me do the swap thru the bottom? Only done top engine removal on rear wheel drive before.
pinkfloyd2388
03-14-2023 01:42 PM
ajith
11-05-2012 11:37 AM
my96accord
06-11-2012 09:15 AM
Tek310
10-16-2011 02:43 PM
jfman
04-15-2007 04:30 AM
Quick Reply: Subframe removal
