-   Engine & Internal (https://www.hondaaccordforum.com/forum/engine-internal-11/)
-   -   06 accord V6 engine removal. (https://www.hondaaccordforum.com/forum/engine-internal-11/06-accord-v6-engine-removal-55523/)
hondatech1 Jun 28, 2013 10:50 AM
hey guys, so I have an 06 accord with the 3.0 V6 and automatic trans. I need to put an engine in. according to alldata they say support the engine, remove the sub frame, move it aside and then drop the engine out the bottom. my question is can I just leave the engine attached to the subframe and drop it all out at once out the bottom? just put some jack stands down and lift the body off? I don't understand why I would have to separate them. OR should I leave the subframe in and take it out from the top? it looks like it would come out the top fairly easy. I have access to a lift, an engine hoist, a trans jack, and pretty much every tool available so that's not an issues. any help would be appreciated.
thanks guys!!!
shipo Jun 28, 2013 12:51 PM
Alldata is tailored to folks with full-on shops complete with hoists, lifts, and jacks of all sorts. For the shade-tree mechanic (like me), pull the sucker out from the top. :)
hondatech1 Jun 28, 2013 01:09 PM
Yea I have a full shop so which ever way is easier, that's the way I'll do. I could see with a manual you couldn't pull it out the top cuz u wouldn't have enough room to slide it out far enough with the clutch and input shaft in the way. But with an auto, it only need to slide off the dowels and TC bolts, which is only a couple inches.
hondatech1 Jun 29, 2013 01:45 PM
Anyone else?
redbull-1 Jun 29, 2013 02:33 PM
See this thread for some info.
Replacing a 2003 V6 Accord Motor... Tips? - Honda-Tech
hondatech1 Jul 2, 2013 10:23 AM
Thanks for that. Some guys there say you can leave the motor attached to the subframe and drop them out together but not really an official answer. As of now that's my plan
