car shake/vibrates when idle
Old 07-06-2017, 11:43 AM
jay2509's Avatar
Default car shake/vibrates when idle
I drive 2007 honda accord ex. 2.4 L engine. My car is shaking for some 5 seconds, whenever I am at the stop signal and car is in D mode and AC turns on. I have showed it to 2 mechanics. They are saying it is because of mounts. Is it because of mount? If yes, do I need hydraulic mount or rubber is fine?
Old 07-06-2017, 12:12 PM
shipo's Avatar
It's a pretty safe bet it's the mounts if two separate mechanics indicate that's the problem. As for what to replace them with, OEM mounts are the safest option.
Old 07-06-2017, 03:32 PM
jay2509's Avatar
Any idea on using hydraulic mount or rubber mounts?
Old 07-06-2017, 03:34 PM
shipo's Avatar
I'm pretty sure Honda put hydraulic mounts in there for a reason; I'd stay with those.
Old 07-10-2017, 09:35 AM
Depends on which specific mount is bad, so match what's supposed to be there.
Honda likes to use vacuum-operated mounts too. They switch from soft to hard on command from the PCM. I hope the mechanics have checked whether it's a bad mount vs a broken wire or leaking vacuum hose??
miro066
05-28-2013 03:39 PM
lebfire1476
04-27-2011 06:05 PM
ksomesula
04-23-2009 05:26 PM
ufosearch
03-15-2009 09:54 AM
HondaAccordFan
11-15-2007 05:09 PM
Quick Reply: car shake/vibrates when idle
