1991 honda accord
It happened again now 2 days in a row i go to start the car and it starts like theres water in the carburetor or injectors or if only 3 pistons are working shaking bogging out the i give it gas and 5 sec later its normal. It just started this after i had the front subframe replaced. Never showed this before and yesterday i was at idle and the temp gauge rose sky high as soon as i stepped on gas and moved forward it slowly went back down and that was it that time.?? Can someone tell me whats going on? ?
A few things come to mind.... First thing I'd do, check the coolant level and if low, I'd bleed the system while filling it up.
If low on fluid, find the leak....this is where the fun starts. Let us know what you find. |
I'm also asking an Admin to edit your user name.
