After heating know have revolution changes at P
Hi!
I have a 96 Accord V6, the last filter and oil service was on October. Yesterday the car overheated, so I turn back home making stops. I was like 1 1/2 mile. Today I put some water to verify if there’s any leaks but nothing happens after 5 min . Then the revolutions star to go up and down (from 1 to 1.5). What you recommend at this time.
Where did you put the water? Open the radiator cap & fill the actual radiator. How much water did you have to add? Did you just refill the overflow bottle?
Honda idle-control systems can get confused if there's air circulating around in the cooling system. Unfortunately, it's also possible something is damaged from the overheating.
johnwill
10-07-2008 11:29 AM
