1994accord ex wagon oil leak
I have a oil leak around the oil filter i don't see any cracks and i have replaced the filter twice. there seems to be a plug or access point above the filter. it is a vtech 2.2 engine thanks mb
Clean it up & see if you can tell exactly where it's leaking. That bolt above the filter is some kind of oil plug, not exactly sure what it's used for. If THAT is where it's leaking, then get a new crush-washer & be prepared to swap it quickly because oil will come out. Or swap it when you change oil.
Hello New Member
Originally Posted by mbhonda1994ex
(Post 189561)
Something else you might want to check is that when you changed oil before that part of or a piece of the old rubber ring from the old filter isn't still stuck on the edge of the oil filter hole..that happened to me a 100 years ago...JUST ONCE :D |
