-   Engine & Internal (https://www.hondaaccordforum.com/forum/engine-internal-11/)
-   -   1996 EX Auto Tran (https://www.hondaaccordforum.com/forum/engine-internal-11/1996-ex-auto-tran-7805/)
Morgan Feb 23, 2007 10:39 PM
1996 EX Auto Tran
Tranny hits a little hard on down shift and sometimes on upshift. It was my grandmother's car and sat idle over a year. AAMCO says the clutches are gone and needs rebuild.... Trans Doctor says they are getting a PO 275 code and trany fluid is leaking and low pressure so lets rebuild.... Both shops say don't change the fluid because it might screw things up worse...WTF!!?? I drove the car car home. My question is this: Can sitting up for over a year be the problem!!?? I know the ATF has never been changed and was low when I got it but I just don't think a Honda Tranny is that weak....Should I just drain the tran and fill it with new Honda fluid despite what the so-calledtrans experts say..HELP!!
sssexy70 Feb 23, 2007 11:32 PM
RE: 1996 EX Auto Tran
Honda makes great manual transmissions... but of this generation the automatic transmission is known to have problems. One term used to describe the shifts is "shift shock". Basically it jerks changing gear. Can you describe the problem in greater detail? Is it slow going into drive? Does it dislike going into reverse? Does it jump changing gears? If you do a rolling stop will it jerk to get into gear? Does the transmission make and odd noises?
My guess is that you are just experiencing what normally happens to this generation's transmission but without more details I don't know what to tell you.
If it is still working fine change the fluid and live with it. If not then start finding a rebuilt tranny!
Morgan Feb 23, 2007 11:49 PM
Rolling Stop... yes, this is when it hits worse. It is hard to guess because I don't know the car. My next angle of attack is to take it to Honda...CAACHING!!!! So I thought... Stokes Honda here in Summerville SC will check it out for 39.99$. I'm hoping Stokes doesn't need to rebuild my trans to pay their tachs for the week... I'll let you know....
Morgan Feb 24, 2007 12:01 AM
I didn't finish answering your questions!!! Sorry. Upshifts seem a little jerky at times but without knowing this car I really can't say it is TERRIBLE. My gut feeling isif you think something is wrong with an auto....it is....
Morgan Feb 24, 2007 12:32 AM
Lent... I think I'll give up my sobriety..............
noboundaries6289 Feb 25, 2007 12:45 PM
how much money do you think it will cost to have a shop rebuild an auto transmission? Either with a stock setup, or performance setup.
brayner Feb 26, 2007 12:19 PM
just a guess- $1600-$1800 stock
noboundaries6289 Feb 26, 2007 05:24 PM
anyone ever put a shift kit on an accord? The mechanic says you can shift from 1-2-d3-d4 and it will act like a 4-speed stick. He said it will cost around $1500. has anyone done this?
YeuEmMaiMai Feb 27, 2007 04:44 PM
OK before you do anything....
Change fluid and add 1 can of lube guard for imports. IF car has been sitting for a while that will help it out.
adamc44 Feb 27, 2007 09:17 PM
if it was me id change the fluid cause what do you have to loose besides 20 bucksif the trans is going out. i changed mine and the car shifts a little smoother. mines a 94
