2000 Accord starter load ratings
Hi all,
After completing valve clearance adjustments in the winter time, the battery and starter in my car failed. Because it was winter time and the engine wouldn't crank too well, I installed a 700 CCA battery. So I'm replacing the starter with a remanufactured starter directly from Honda. Do you think that this new starter can handle this battery, or should I go down to 500 CCA? It is an accord from 2000 with a v6 and automatic. |
You will be fine.....
(Post 318344)
