2002 Honda Accord Loosing Oil
Old 01-23-2017, 10:40 AM
timwuzhere's Avatar
Default 2002 Honda Accord Loosing Oil
Hi everyone, I have a 2002 Accord 2.3 vtech with around 150k and its been loosing oil, I have replaced the PCV valve, I have had the o-ring on the distributor replaced and I have had the valve cover gasket replaced, I never find any oil on the ground so it must be while I am driving. Before the valve cover gasket was replaced I could smell oil burning but that seems to have gone away, Is there any other place these cars leak oil from. Any help would be great.
Old 01-23-2017, 02:59 PM
Oil can leak from distributor/cylinder head oring and internal distributor seals (allowing oil to drain from distributor cap).
Crankshaft (driver's side) seal, camshaft seal, balance shaft seals (all under timing belt) can all leak. Oil from bottom of timing belt cover would indicate one of these.
Vtec solenoid valve (back side of cylinder head) is another frequent leak point.
Old 11-22-2017, 07:31 PM
fast eddie's Avatar
Is it burning the oil? Smoking at all??? Even if it doesn't smoke it can use oil...mine uses a quart every 500miles or so...
Old 11-24-2017, 02:53 PM
Jet sitter's Avatar
Oil pressure switch, another location. I personally use about a quart every oil change 5K miles. The car has 245K miles on it, so IMO, it's well within spec.
SirJohnIII
11-05-2015 01:46 PM
grocerygetter96
06-29-2013 10:34 PM
bustum
04-11-2012 02:10 PM
1accord1996
04-07-2011 12:36 PM
Mikkos
02-26-2010 03:19 PM
Quick Reply: 2002 Honda Accord Loosing Oil
