2003 honda accord lx running hot
Hello i have a 2003 honda accord lx with 130k miles and it's running hot. The resavor is always full. I am always having to put water or antifreeze in the radiator. The fan's are cutting on. Please help!!!!
Have a shop perform a cooling system leak test to ID leaking site/s, or not. If no external leaks are found and cooling system loses pressure, the cylinder head gasket may have failed.
A bad thermostat can also cause overheating, but would not account for loss of coolant. Resolve leak first. good luck |
Well i went to go put water in my radator this morning and the resavor was empty. My car has been running hot for a couple of month's and the resavor has always been full!!! I don't get it:confused:
You need to find the leak.....the coolant is going some where.
