2010 Honda Accord Valve Adjustment
Here is what I was told about valve adjustment from Dealer. Is this true? Thanks for your input.
Spark plug and valve adjustment (4) $491....It's always recommended to adjust valves every 7 years or 100k miles. We wouldn't know if valves are too tight or loose by looking at them, we would have to actually preform the valve adjustment to get the before and after specifications. Let me know if you have any questions, I would be happy to answer them. Thank you. |
Pretty much true, unless you want to get real technical with terminology.
If the valves are loose, they'll make ticking sound when the engine is running. If they're too tight, they don't make noise, but can result in burned valves & a real expensive repair if you leave it go forever. In order to MEASURE the valve clearances, they have to remove belts & valve cover & stuff, which is a large part of the job. Technically, ADJUSTING the valves is just loosening a locknut & turning a screw. But in reality the mechanic has already spent all the time just to get into that mechanism before he can even measure to decide if they need adjusting. It would be kinda silly for a shop to charge 2 hours 52 minutes of labor (wild guess) for measuring the valves, then charging 8 minutes for adjusting them. |
Originally Posted by jeffbantle@gmail.com
(Post 383014)
Valve adjustments
I was told that there is no way to know until they open up?
(Post 383028)
Valve Adjustments
Shipo,
I do not see in my owners manual where it states do the work when valves are noisy. Just says inspect when changing spark plugs. |
(Post 383044)
Shipo,
I do not see in my owners manual where it states do the work when valves are noisy. Just says inspect when changing spark plugs. https://cimg1.ibsrv.net/gimg/www.hon...f442eb432e.png |
Sorry for the very delayed response. I had the dealership do the valves. They never recorded the before and after.
