is 260 - 300 hp possible on an accord ?
I am getting an accord 2002 v6 automatic stock 200hp and i would like to go about 260hp atleast preferbly 300hp...
What are my options? i can put up to 2k's into the engine?? Any suggestions & websites are welcome... |
RE: is 260 - 300 hp possible on an accord ?
For $2000, you arent going to get anywhere near 300hp, unless you use nitrous. You would need to put a lot of money into your engine to get to 300hp.
I can't put 60hp for $$2000 ?? Thats pretty ****ty then ...
Its not like a Chevy 350, where you can just put on headers, intake manifold and a bigger carb and get a ton of horsepower. Honda engines are already efficient, its harder to free up more horsepower. You could maybe piece together a turbo kit for less than $2000, if you install it yourself.
http://www.hondatuningmagazine.com/f...ged_accord_v6/
Check out this article, see how much work was done to this car for 230hp at the wheels. Thats another thing I should have asked, are you looking for 260-300hp at the wheels or at the crank? |
wow supercharged and only 230? i am looking at the wheels.... the v4 seems to have more options to get hooked up then v6
should i go with the v4 then?? |
Okay here's the thing. There are more options for performance, a wider selection, for the four cylinder. HOWEVER, my car is a 94 LX, with engine code F22B2. Its factory rated at 130hp at the crank. The 94-97 EX with VTEC is factory rated at 145hp at the crank. So while there are more options, your 200hp at the crank V6 is already 70hp ahead of mine, both stock. There's no way to take my car from stock to 260hp for $2000, it just wont happen. Believe me, I wish it COULD happen! If you want a lot of hp for minimal dollars, do what YeuEmMaiMai did, buy an Acura CL-S. I believe he just put an intake and headers on it, took it from like 260hp to 307hp. Thats an extreme case, though, not every car is able to do that. Im also not sure how much it cost him, performance stuff for that car probably costs more than for an Accord, since it isnt as mass produced.
buy a K24 or a 2003 V6 they come stock with great power and with 2k u can probably hit 300 in the V6 and 250ish in the 4 banger...
I really doubt you will be able to hit 300hp at the wheels with $2k on an 03-up V6. Its 240hp at the crank stock, but adding that much power for that cheap is really difficult.
man the aftermarket for the V-6 is CHEAP cams intake exhaust headers and some tuning (megasquirt be good) + some custom grounding work... will take it up to 300
