5th gen. k swap questions...
Does anyone know if a k24, with 4wd (element driveline) will fit into the front end of the car, I can make room for driveshaft and other pieces in the back. I think an awd accord would kick some serious butt...
thanks for any help |
RE: 5th gen. k swap questions...
wow youll have some serious work on your hands if you tried that but that def. sounds like a cool idea
wow that would be awesome! and alot of work. honda should make some competition to the wrx/sti impreza.
its just too bad accords dont have the body to properly have a drive shaft running to the rear wheels without raising the rear redoing the whole rear suspension and a whole parts list to finish it off..... might as well buy an wrx at that point
and its an impreza wrx sti |
ORIGINAL: tommyboy Does anyone know if a k24, with 4wd (element driveline) will fit into the front end of the car, I can make room for driveshaft and other pieces in the back. I think an awd accord would kick some serious butt... thanks for any help |
