700 HP: Truth, False, or Possible?
I heard from one of my friends that a guy he knows has a Honda Accord, 94-97 model with the USDM 2.2 L 130 HP motor, and he was able to soup it up to around 700 HP without a turbo. Could that be true, or is he lying or overexaggerating? If it's possible, what would have to be done to achieve such power? If it isn't possible, then what's the most horsepower that I could possibly get from souping up such a car? I'd like to one day drop a H22A7 into my 97 Accord. With that engine, how much HP could I free up in the end after souping it up? Thanks in advance.
RE: 700 HP: Truth, False, or Possible?
Hahaha...700hp w/out a turbo. Chea right, what's he been smoking. The most power out there from a N/A (naturally aspirated) non turbo'd F22 is around 300-350whp and its completely race only.
The amount of power you wanna make is dependent on how much cash flow you have. |
with a H22 you can easily get 400hp easily and reliably. that is about as much as i would run on a street car, even then you would run into traction problems and be paying alot for gas.
Maybe he pulled it off without a turbo because he put a Supercharger on there *L* or Nitrous, but there is absolutly no way that engine can produce 700HP Naturally aspirated. Good story though..... Ask him if the guy he knew was using a rotory engine, if he says yes then just snicker to yourself and walk away...
Liar |
Uh, what are you guys on:eek:? Of course its possible.
My f22 has 563 hp just from an intake and headers. |
How about one with a 671 Blower and this here wing,,,maybe 500HP !
[IMG]local://upfiles/22/553E7D99639A48FDA56D991446FF896C.jpg[/IMG] |
hell the biggest NA K series i have ever seen was 325 and thats a far better engine then the H or the F Fseries are capable of 500-800 MABY if they are turbo and built right
H22 with a 100mm bore and 97mm stroke 12:1 comp and a crap load of tuning in a 2400ish lb prelude can get you close to 300hp.
I put the tornado intake thing on my m3 and now it pushes over 1000rwhp.
