Is the 90 accord front core support bolt in?
i have a 90 accord and i recently just wrecked it i need to know if the core support is bolted in or if its welded because i might need to replace it if it cant be reshaped and adjusted back to normal.
Thanks everyone, Chris |
RE: Is the 90 accord front core support bolt in?
nok1...in having worked around shops..i greatly doubt that you wil be able to reshape it...unless the bends are very minor...to replace it, the engine front fascia, fenders, so on, will likely have to come off...any body shop or real honda technician would be able to tell you...do you have the car at your house, or is it at a shop somewhere? i would start along the rad, and follow the support outward looking for a seam, wther boltded or welded..it is probably well towards the inner fener...
