92 Honda Accord wagon. Code 9 No.1 cylinder position sensor
I have a 92 Honda Accord wagon automatic and I have a code 9 ( No.1 cylinder position sensor) My distributor have 5 wires on it ..so my cyp is not in there ...do anyone know where I can find it ... So this is what happen to my car I was pulling out my driveway and it shut off my starter , battery ,and alternator all died so I replaced them and ny car won't start so I put a paper clip in my reader and got a code 9 ( No.1 cylinder position sensor) but I can find it no where .....HELP PLEASE it's been 3 weeks now and I Google and search every where |
You need to get a new distributor
I did that 2 times and it still doesn't work I check for spark to in the spark plugs I'm good there my fuel pump work , I put in a new main reley switch ... Anything else and also my distributor has 5 wires
When you put the distributor in what steps did you take
None really I just made sure it was lined up and I understand hook the battery to erase the code but nothing still ..did I miss something
Not to sound crazy but my timing belt (TDC) or can I use a timing light
When you put the distributor in were you at tdc or just marked the location of the dial. No need for the timing light.
Not sure about to go check in 15 min and will let you know
So i check it and it's all lines up
| All times are GMT -5. The time now is 04:31 AM. |
