93 octane
i usually use 87 octane fuel, but my friend says that 93 octane is better for your engine. i have a 95 accord ex with 175k on it. i was wondering if i switched to 93 octane if it would mess up my engine somehow or have any disadvantages. does anyone know anything about this?
RE: 93 octane
ORIGINAL: sdub102 i usually use 87 octane fuel, but my friend says that 93 octane is better for your engine. i have a 95 accord ex with 175k on it. i was wondering if i switched to 93 octane if it would mess up my engine somehow or have any disadvantages. does anyone know anything about this? |
RE: 93 octane
That's how the gas companies get you at the pump....by preying on assumptions and insecurities.
Just get 87....the engine was designed that way. |
RE: 93 octane
Agreed. The V-6 will respond to higher octane but it is a waste of time and money for the 4 cylinder.
RE: 93 octane
why will the v6 respond and the i4 wont?
its a waste of $ unless its required. |
RE: 93 octane
i have the same type of car with 175k on it as well. I use synthetic oil with no leaks and use premium fuel. Personally, I never got a chance to know what 89 octane performed in it. I put 93 in it since I got it. No smoke, No knocks, i'm happy with it.
RE: 93 octane
Wish I had 93 octane here in Cali. Highest we have is 91 octane.
RE: 93 octane
ORIGINAL: smaglik why will the v6 respond and the i4 wont? its a waste of $ unless its required. |
RE: 93 octane
ORIGINAL: smaglik why will the v6 respond and the i4 wont? The 4-cyl ECU has maps for spark timing & mixture over the operating envelope of the engine. The knock sensor can retard the spark from that map, but the ECU is probably not programmed to advance the spark beyond the map. So if the knock sensor is NOT hearing any knocking, it won't go hunting for the point of incipient knock. Maybe the spark map for the V-6 is set up with enough advance sothat the ECU has to pull back the spark when it has 87 fuel?? I was not aware that Honda would have done this... |
RE: 93 octane
That sounds correct now that you mention it. I forget where I read the article but it was straight from the3.0l V-6 engine designer@ Honda. Some intense googling may bring it up.
