98 accord engine problem
I had my 98 accord v6 timing belt and water pump change about a month ago. when i start up the car, its making some weird noise, sounds like its rubbing against something. Does this about everytime the car is started up and probaly while running.
Any solution to this problem or probaly bad repair? |
RE: 98 accord engine problem
Did you change the tensioner with the repair, it could be that.
ORIGINAL: scheung1990 I had my 98 accord v6 timing belt and water pump change about a month ago. when i start up the car, its making some weird noise, sounds like its rubbing against something. Does this about everytime the car is started up and probaly while running. Any solution to this problem or probaly bad repair? |
