99 Accord 4 cyl Timing Belt
Does anyone know if the 4 cyl. engine on my 99 accord is interfering or non-interfering. i haven't had time/money to replace the timing belt and its over 105k. Anyone know for a fact either way? thanks.
RE: 99 Accord 4 cyl Timing Belt
It's an interference engine. If the belt breaks, the pistons can hit the valves.
Yeh honda engines depend a lot on the timing belt. As long as you keep it replaced whenever the time comes your engine will be fine. I'd advise you to change yours just to be safe.
ORIGINAL: jombolo . i haven't had time/money to replace the timing belt and its over 105k.. |
Plus I wanted to add that even though the belt might not break apart - it does stretch - so as you are driving it further you might experience bad acceleration and/or worse gas mileage
