Accord 2004 Automatic Transmission oil
I am using 6cyl Accord 2004 with automatic transmission. Dealer told me that i must change automatic transmission oil after 80,000KM.
People says that usually changing the automatic transmission oil destroys the gearbox etc and ends up in lots of problems. Friends says better dont touch it unless its dirty. Please help me on that. |
RE: Accord 2004 Automatic Transmission oil
If it was mine i'd change it more often than honda reccomends. New fluid isn't going to hurt it. Use Honda ATF.
ORIGINAL: oziking I am using 6cyl Accord 2004 with automatic transmission. Dealer told me that i must change automatic transmission oil after 80,000KM. People says that usually changing the automatic transmission oil destroys the gearbox etc and ends up in lots of problems. Friends says better dont touch it unless its dirty. Please help me on that. |
the 5spd auto used in those cars is the same one used in the Acura CL/TL cars. It is STRONGLY RECOMMENDED that you change the fluid every 30K miles
thanks a lot for your answers i will get it changed soon.
Really appreciated |
ORIGINAL: YeuEmMaiMai the 5spd auto used in those cars is the same one used in the Acura CL/TL cars. It is STRONGLY RECOMMENDED that you change the fluid every 30K miles. |
