Accord/Prelude Trans & Gear Ratios
USDM F22A1 90-93 ACCORD DX/LX COUPE/SEDAN:
Diff Type & Tranny Codes: STD Only = MPT3 3.307 1 1.809 2 1.230 3 0.903 4 0.705 5 4.062 final 5th gear 195/60 R15 70mph = 2782 rpm 80mph = 3180 rpm USDM F22A4/A6 90-93 ACCORD EX COUPE/SEDAN: Diff Type & Tranny Codes: STD Only = H2U5 3.307 1 1.809 2 1.185 3 0.870 4 0.685 5 4.062 final 5th gear 195/60 R15 70mph = 2703 rpm 80mph = 3090 rpm USDM F22A1 92-96 Prelude S COUPE: Diff Type & Tranny Codes: STD Only = M2L5 3.307 1 1.809 2 1.230 3 0.903 4 0.705 5 4.062 final 5th gear 195/60 R15 70mph = 2782 rpm 80mph = 3180 rpm USDM H23A1 92-96 PRELUDE Si COUPE: Diff Type & Tranny Codes: STD Only = M2S4 3.307 1 1.857 2 1.320 3 1.034 4 0.812 5 4.266 final 5th gear 195/60 R15 70mph = 3366 rpm 80mph = 3847 rpm USDM H22A1 93-96 PRELUDE VTEC COUPE: Diff Type & Tranny Codes: STD Only = M2F4 3.307 1 1.950 2 1.360 3 1.071 4 0.871 5 4.266 final 5th gear 195/60 R15 70mph = 3610 rpm 80mph = 4126 rpm USDM H22A4 97-01 PRELUDE VTEC Non-SH COUPE: Diff Type & Tranny Codes: STD Only = M2Y4 3.285 1 1.956 2 1.344 3 1.034 4 0.812 5 4.266 final 5th gear 195/60 R15 70mph = ? rpm 80mph = ? rpm JDM H22A 92-96 PRELUDE VTEC COUPE: Diff Type & Tranny Codes: STD = M2A4 LSD = M2B4 3.307 1 1.950 2 1.360 3 1.034 4 0.787 5 4.266 final 5th gear 195/60 R15 70mph = 3262 rpm 80mph = 3728 rpm USDM F22B1 94-97 ACCORD EX VTEC COUPE/SEDAN: Diff Type & Tranny Codes: STD Only = P2U5 3.285 1 1.807 2 1.193 3 0.933 4 0.685 5 4.062 final 5th gear 195/60 R15 70mph = 2703 rpm 80mph = 3090 rpm USDM F22B2 94-97 ACCORD DX/LX non-VTEC COUPE/SEDAN: Diff Type & Tranny Codes: STD Only = P2A5 3.285 1 1.807 2 1.193 3 0.903 4 0.685 5 4.062 final 5th gear 195/60 R15 70mph = 2703 rpm 80mph = 3090 rpm USDM F22BX 94-97 ACCORD LX/EX WAGON: Diff Type & Tranny Codes: STD Only = P2A4 3.285 1 1.807 2 1.193 3 0.903 4 0.685 5 4.266 final 5th gear 195/60 R15 70mph = 2839 rpm 80mph = 3245 rpm JDM F20B ACCORD SiR-T VTEC: Diff Type & Tranny Codes: LSD = T2T4 3.285 1 1.956 2 1.344 3 1.034 4 0.787 5 4.266 final 5th gear 195/60 R15 70mph = 3262 rpm 80mph = 3728 rpm JDM F22B Prelude Si non-VTEC: Diff Type & Tranny Codes: STD = M2J5 3.307 1 1.810 2 1.269 3 0.966 4 0.787 5 4.062 final 5th gear 195/60 R15 70mph = 3106 rpm 80mph = 3550 rpm JDM ACCORD Euro-R VTEC: Diff Type & Tranny Codes: LSD = T2W4 3.285 1 2.090 2 1.481 3 1.071 4 0.812 5 4.266 final 5th gear 195/60 R15 70mph = ? rpm 80mph = ? rpm EDM ACCORD Type-R VTEC: Diff Type & Tranny Codes: LSD = U2Q7 3.285 1 2.090 2 1.481 3 1.071 4 0.870 5 4.266 final 5th gear 195/60 R15 70mph = ? rpm 80mph = ? rpm JDM PRELUDE SiR S-spec: Diff Type & Tranny Codes: LSD = M2Z4 3.285 1 1.956 2 1.344 3 1.034 4 0.812 5 4.266 final 5th gear 195/60 R15 70mph = ? rpm 80mph = ? rpm |
This is a good information post TEK310.
Thank You for posting it for all the members of the HAF.... |
As a matter of principal. I have made this a sticky..Thanks Again....
Hello TEK310,
I just chewed second gear in my H2U5 tranny out of a 91 honda accord. I am wondering if I can do a swap of the main and countershaft of my H2U5 with another tranny without doing any modifications. I was just going to change the internals. I am just trying to do my homework, if I can't find an H2U5 at the local junkyard. I read about some changing the fifth gear on their ludes with the 5th gear from the H2U5. I was also told that the D2A4 (90 - 91 honda prelude) is the only one that will work with the H2U5. Looking at the gear ratios that you listed, which one would you recommend. This is my daily driver, not going to race or anything but would like to have a little performance. More like a sleeper. |
