accord trouble
I just replaced the injector o-rings on my 1994 honda accord and now it's bogging out when I come to a stop. Whats wrong??
A fuel leak or air leak is possible when replacing the injector/manifold seals. The injector/fuel rail seals can be damaged leading to loss of fuel pressure (and safety hazard) or intake air leak due to improperly seated injector/manifold seal. Suggest carefully inspecting your work.
Did this problem originate w/ this work on fuel injector seals? Is Check Engine Light on? If yes, check for obd1 codes. good luck |
