Adjusting idle
Do i actually need to use a tachometer and disconnect EVAP solenoid before adjusting the idle screw in park? I own a 1998 honda accord 4 cyl ex my car is idling a lil higher then 750rpm after installing new spark plugs and spark plug wires.
Originally Posted by Roch.nicholas
(Post 322861)
Originally Posted by 94ex915
(Post 322865)
750 doesn't sound to abnormal. Then again I don't know to much about your year. Lets see if anyone else could be a better help.
There is a write up by Jim in the Common DIY threads sticky in the top of the general tech section about checking/adjusting the idle.
Kk thank you
