'Big 3' electrical upgrade.. advice needed
Hey all, I'm getting ready to do the 'Big 3' upgrade on my 91 accord ex, and I'm wondering if anyone here could tell me about how much cable I'm going to need for it. I'm guessing around 10 feet of 0/1 awg, just to be safe.. but I don't want to buy more than I need. Also, does anyone know what the stock battery/alt wires are, in terms of awg? They appear to be between 2 and 4 awg.. but it's hard to tell. TIY, -mak |
RE: 'Big 3' electrical upgrade.. advice needed
I'd buy extra since wire isn't that expensive, but if you want to save a couple bucks, measure the existing ones with a taylor's tape measure, then add a foot. This will give you 2" on every end to play with. 2" * 3wires * 2 ends = 1 foot
ORIGINAL: falkore24 I'd buy extra since wire isn't that expensive, but if you want to save a couple bucks, measure the existing ones with a taylor's tape measure, then add a foot. This will give you 2" on every end to play with. 2" * 3wires * 2 ends = 1 foot I'm not sure what the stock wires are either though. Sorry |
I think they are smaller than 4AWG.
If you'd like, I can scan a calculation that I had to do last week that took 2.5 days (including plan takeoffs and learning the system). I had to figure out the weight of ammonia in a deep freeze facility, measuring pipes down to 3/4" with ammonia in mixed gas and liquid phases at temps between -24 deg and +95 deg ..... the total was almost 55,000 lbs. |
ORIGINAL: falkore24 If you'd like, I can scan a calculation that I had to do last week that took 2.5 days (including plan takeoffs and learning the system). I had to figure out the weight of ammonia in a deep freeze facility, measuring pipes down to 3/4" with ammonia in mixed gas and liquid phases at temps between -24 deg and +95 deg ..... the total was almost 55,000 lbs. I started incollege as a mechanical engineering major (kept at it for a year) so I know how complicated thatstuff can get. First year would be merely the tip of the iceberg. I was alwaysreally good at math, so I figured I might be an engineer. Then I figured out that even thoughI wasreally good at it, I didn't really like it all that much haha. So I switched to accounting (bad choice.) I figured out quickly that would rather dig ditches for the rest of my life than be an accountant. Then I finally got into insurance and liked it. At least I never had to take business cal. haha we covered all of that in one month! |
I don't necessarily like math, but it is a necessary evil of my profession. Thankfully I don't have to do those kind of calcs that often. I do enjoy research on a decent topic though.
Wouldn't it be much cheaper just to get an eBay grounding kit for $25 rather than spend all that money on overkill 4AWG or bigger? I bought an "HKS" (lol) earthing kit and it had 6 or 7 varying length leads on it with a new battery terminal. Great investment because 30 feet of 4AWG copper isn't cheap.
| All times are GMT -5. The time now is 09:57 AM. |
