Big Rad Problem!!!
Apparently the mesh on my radiator has been falling out for the last several years and almost a quarter of it is missing! My air conditioning has not been blowing cold air either... could this be a contributing factor? And what is a reasonable price to fix or replace my radiator... gimme some advice please! hahaha... I'm a loner...
RE: Big Rad Problem!!!
I checked out tasauto.com (link at top of page) and saw a replacement radiator on there for about $120. Then you gotta pay shipping. You may be able to find a radiator for less if you shop around.
As far as the a/c not cooling, I wouldn't think that should have a lot to do with the radiator mesh falling out. Somebody correct me if I'm wrong though. Has the car been running hot? How long has the a/c not been working? |
If you're looking into the front of the grille, that's the AC condensor that you see. Is that where the fins are falling off?
To see the radiator, open the hood &look in thru the fan blades. If you already know this, sorry... I was just ruling out a simple misunderstanding. |
Yes, I did know this... Definitely the radiator... especially because the loose mesh keeps on gettign caught in the fan and gets pulled out...
Put a radiator in it.
ORIGINAL: Chiovnidca Put a radiator in it. |
ORIGINAL: JimBlake ORIGINAL: Chiovnidca Put a radiator in it. |
Getting a new rad then... expenses are expensive... no more headers for a while now...
seeing as you have to replace it might as well get a bigger then stock one ^_-
