A/c
So today i tried to recharge my ac and found out i have a leak under the high pressure line and low pressure line on the fire wall. It is a little piece of a broken tube sticking out from the firewall its leaking from. Not sure what it is but i cannot find where it goes to i looked everywhere. Not sure if its the evaporator drain tube but i own a 1998 honda accord coupe 4 cyl if anyone has a diagram or knows what the tube is would be very helpful. I also have a picture im going to try and upload
Pretty sure its the refrigerant drain tube..
The drain tube drains water....if water is leaking out...that is good :)
If the freon (134) is leaking out, that is bad :( |
Lol i feel like a dumbass its only water lol but the ac is still not working i replaced the cabin air filters and air filter.. The compressor turns on and the fans turn on belts are tight enough and brand new. Im not sure what it could possibly be and if its easy to fix.
Also added 22oz of artic freeze nothing is working...
Anyone know why it would still not be working?
