a/c eliminator kit
looking for one for an f22a1. anyone know where to get one?
RE: a/c eliminator kit
ORIGINAL: pr3z looking for one for an f22a1. anyone know where to get one? |
pully and belt that mounts in the holes ur AC comp did
why not just get a differant sized belt?
Honda lists an alternator belt for cars without a/c.
couldnt find it and when i called honda they said that a/c was a standard on them. ill keep looking though.
ORIGINAL: legionofone pully and belt that mounts in the holes ur AC comp did |
if i ran a shorter belt it would scrap pretty deep into the timing belt cover and i'll go through a couple of belts before it you run clean through. i could take it off the coverand cut it but i'd rather get the eliminator kit and just drop it in. its not that i dont want the a/c because i live in south fla but its bad and i'd prefer to ditch it rather then fix it.
ORIGINAL: pr3z if i ran a shorter belt it would scrap pretty deep into the timing belt cover and i'll go through a couple of belts before it you run clean through. i could take it off the coverand cut it but i'd rather get the eliminator kit and just drop it in. its not that i dont want the a/c because i live in south fla but its bad and i'd prefer to ditch it rather then fix it. |
just by installing a shorter belt should not change the alignment of the belt .. like Chio says , there is something wrong that allows the belt to scrape the cover,, but ,, if that's the case , then even the longet belt should scrape on the cover
And do not cut the cover,, you do not want any debris and such to get inside the timing belt cover |
