Car dies randomly....
I was wondering if anyone has had a problem with their battery just dying randomly. I drive my 94 accord everyday with no problem. But every now and then it just dies and the battery is completely dead. I have to jump it every time. Anyone have any ideas????
RE: Car dies randomly....
Sounds to me like a bad clamp on one of your wires... it's one of those things that you would never think of and then it'll cost you $7 to fix...
Also check your cable that goes down to your starter and the ground cable to the fram to see if it's correded..
WheelBrokerAng [sm=americanasmiley.gif] |
check for shorts and paracitic draw...
first thing you should do is to have the charging system tested,, ( alternator, battery, cables , ) if it is ok, then chk for a drain in the electrical system .. have a shop do it or you can go to our DIY section,,and read up on the post ( battery going dead ) pg 3 ..
My battery has been dying too. Over night or when its off for a few hours. I have tested the battery, wires, and alternator. I have also changed the clamps on the battery, new and tighter ones.
I have turned the alarm on thinking that may help. And this morning its dead again. I do have one of those battery recharger. Plug it in the wall-recharge-plug it to the battery- kinda of thing. So iv been starting my car that way for the past two days. Should i go ahead and checkfor anelectrical system drain? |
