CKP Sensor
i recently did the obd II code reader test on my car and it was throwing out the code P0335 which was Crank Shaft Position Sensor Malfunction, is it necessary to replace the whole crankshaft position sensor? or is it just a wiring problem. I recently changed out my timing belt, and now the car won't rev past 3000rpm. The belt snapped but there seems to be no problem with the compression and no bent valves. thanks in advance for the advice.
do you guys know how much a CKP sensor goes for(h22a4)?? |
RE: CKP Sensor
This recently happened to my gfs civic. Don't know if this will help but the mechanic found that there was a short in the wire due to water. Mechanic said some grommet corroded and allowed water in. Maybe there is something wrong with the wiring and not the sensor? I don't know much about wiring so hopefully somebody else will chime in.
RE: CKP Sensor
Take the timing cover off and check the sensor and its wiring.
RE: CKP Sensor
there were a couple rips in the wiring but i already taped it up, how would i know if the actual sensor was damaged?
RE: CKP Sensor
Test it with a voltmeter.
RE: CKP Sensor
ORIGINAL: doanutboi there were a couple rips in the wiring but i already taped it up, how would i know if the actual sensor was damaged? |
RE: CKP Sensor
any other advice guys? the new ckp sensor is 187..[&:]..and right now i dont have that kind of money to spend. with christmas coming up and all
