Condensation on the inside back window
Hello everyone, I have a 1992 Accord and it runs great. The problem is that the back window is wet on the inside. I don't know but I took it into an auto body shop and they could not find a bad seal. Everything seems to be dry but the back window. It's weird I will get out of school and go to my car and the back window will be wet. I don't know where this moisture is coming from, thanks for your help!
RE: Condensation on the inside back window
dude check to see if you have water where your spare tire is at .... last time my sister had a similiar issue and she was dragging along a galon or two down whre the spare is at
If the glass is below 60, the AC compressor is not on or working right and the windows are closed, the glass will fog, then sweat. Simple psychrometrics man.
Is the ventilation system set to RECIRC mode? It should NOT be that way when youre trying to defog the windows.
