considering head swap...
I want to have vtec on my engine without doing a full engine swap.. I know you can bolt a vtec head up to a non vtec block... but for a 90-93 accord, what vtec head shall I use.. I dont want super high compression, simply because I am going to boost it...
so what vtec head should I get? and are the exhaust ports the same? cause I want to bolt my 90-93 turbo manifold to the new vtec head.. |
RE: considering head swap...
If you want vtec you are going to need a new ecu also. I am not sure which vtec head would match to that engine. Maybe an f22b1?
ORIGINAL: 00AccordLX5spd If you want vtec you are going to need a new ecu also. I am not sure which vtec head would match to that engine. Maybe an f22b1? |
The most direct bolt-up would be the H23 head. All F and H engines (with the exception of the F20 from an S2000) are interchangable with varying degrees of modification. BUt the H23 is the most direct fit on the F22A if you just want DOHC. The H22A head also bolts up very nicely.
i have a f23 on my 02 accord so i would be able to put up a h22 or h23 head on it? and whay would it do as of power if any?
the H head is better for NA, the F head is better for boost or nitrous
ORIGINAL: 02BlueAccord i have a f23 on my 02 accord so i would be able to put up a h22 or h23 head on it? and whay would it do as of power if any? If you swap an h22 head on there, you would be able to use many of the h22 mods (more available than for f23) |
oh ok thanks. would i have to replace my headers and intake as well? or would they fit
I imagine you would have to replace. The intake might fit.
oh ok thanks.
