couple H22 questions
1) whats the difference between a H22a1 and the H22 type-s, i have a feeling its just the red valve cover and different cams, but i would like to know for sure.
also 2)I read in the latest modified mag that the timing belt tensioner on H22s fail fairly often, is this true, and if so is there a aftermarket one you can buy that isnt likely to break. thanks Cameron |
RE: couple H22 questions
1) Different ignition setup at the distributor (internal vs. external coil), 50mm mains (h22a1) vs 55mm mains (type-s), compression and pistons10.6:1 (a1) vs. 11:1 (type-s), cams (type-s has more aggressive).
2) Many switch to the H23 tensioner. There is a write up on how to do it on Honda-Tech.com |
ORIGINAL: BlkCurrantKord 1) Different ignition setup at the distributor (internal vs. external coil), 50mm mains (h22a1) vs 55mm mains (type-s), compression and pistons10.6:1 (a1) vs. 11:1 (type-s), cams (type-s has more aggressive). 2) Many switch to the H23 tensioner. There is a write up on how to do it on Honda-Tech.com what makes the Type S so beastly are the higher compression cams and pistons as previously mentioned as well as the factory port and polish. you can get a regular h22 and do all that stuff for cheaper than buying a Type S. |
thanks for the great information guys, just what i was looking for, I figured it wasnt worth the extra like grand for the type-s
ORIGINAL: live2rice thanks for the great information guys, just what i was looking for, I figured it wasnt worth the extra like grand for the type-s |
ORIGINAL: live2rice 1) whats the difference between a H22a1 and the H22 type-s, i have a feeling its just the red valve cover and different cams, but i would like to know for sure. also 2)I read in the latest modified mag that the timing belt tensioner on H22s fail fairly often, is this true, and if so is there a aftermarket one you can buy that isnt likely to break. thanks Cameron h22a1 = obdI h22a4 = obdII h22a S = obdII Auto tensioners are what h22's use for adjusting the tension in the timing belt. People take them out when they decide to build their motor as they have been known to fail but for regular applications they work just fine. If you do decide to "upgrade" the tensioner than you can go with an h23 manual belt tensioner conversion. |
Sounds like a freaking beastly motor....luck on the install live2rice
ORIGINAL: 03Sleeper Sounds like a freaking beastly motor....luck on the install live2rice |
ORIGINAL: Velocifero ORIGINAL: 03Sleeper Sounds like a freaking beastly motor....luck on the install live2rice i dont think i have enough knowledge to install it myself, i could probably physically get it in, but not wire it up. and it costs more to have it installed than the engine costs. think i might just have to bite the bullet and pay the money for someone to install it. |
