Cruise control not working ??
Does your speedo work? I have an intermittent problem with my '94 Accord where the speedo stops working, and at the same time Cruise control stops working.
I think this is probably caused by the axle speed sensor being on the blink.
Search for "VSS" or "vehicle speed sensor" - should be plenty of good stuff, probably most in the General Tech area.
If the speedometer still works while the cruise doesn't, then it's a different problem.
And... it's not internal engine stuff, so I'm going to move this over to General Tech.
aatc20
09-25-2006 04:28 PM
