Does Idle set itself?
Old May 12, 2006 | 06:26 PM
FlyLow's Avatar
Default Does Idle set itself?
I had a check engine code erased by AutoZone on my car, right as they finished I went driving and noticed the unusually low idle RPM's, looked like under 500. It felt like the car wasn't running it was so low, but it was. Then after driving the car, idle rpm's went back to normal. Does the computer adjust itself after sometime? Why did it get so low anyway?
99 LX coupe 5-speed
Old May 12, 2006 | 10:15 PM
Chiovnidca's Avatar
Default RE: Does Idle set itself?
ORIGINAL: FlyLow
Yes it does. Due to variances in the different sensors, the ecu has to learn their normal values before it can determine where to set the idle. When they cleared the codes they also cleared the learned values it needed to determine idle speed. The easiest way to get it back is to do the idle learn procedure: Warm the engine up to normal operating temperature, then let it idle with all loads turned off for 10 minutes.
Planefreak
Apr 8, 2014 04:23 PM
steve_nufc
Jan 16, 2008 03:33 AM
Andz619
Feb 22, 2007 09:18 PM
cenkaetaya
Feb 13, 2007 03:54 PM
