Electric Problem
I have a 1998 accord, when this cold is a flaw in the engine. This bug seems to be electric. When the engine heats up the problem. It has changed the petrol pump, spark plugs and spark plug wires. I need Helps. ******* Tengo un accord 1998, cuando esta frío tiene una falla en el motor. Este fallo parece ser eléctrico. Cuando el motor se calienta desaparece el problema. Se le ha cambiado: la bomba de la gasolina, las bujías y los cables de las bujías. Thanks. |
Welcome new member!
Describe the problem a little better so we can help. |
My Spanish is rusty, but he said something along the lines of:
"I have a 1998 Accord, when it's cold I have an error in the engine. This fault seems to be electric. When the motor is hot, there doesn't seem to be a problem. I have changed: the fuel pump, spark plugs, and wires." Honda1611, ¿Su motor al ralentí áspero? ¿El motor de salto de 600 a 1200 rpms hasta que el motor está caliente? Esto suena como obstruido EGR puertos. O bien, podría ser una sucia IACV o FITV válvula. |
Please Type In English Only
And in the correct forums always...
WheelBrokerAng |
Finch, the 1998+ does not have a FITV.
Thanks for reminding me... I should've known better since I have the same car...
