Engine Shakes
I have an Automatic Transmission, when I put it on reverse it shakes BADLY and now lately it shakes when I stop at a light and then it goes away when the car warms up. How much is the repair and what is it? anything I can tighten or loosen myself?
RE: Engine Shakes
i think you should check your motor mounts
RE: Engine Shakes
ORIGINAL: stevent i think you should check your motor mounts |
RE: Engine Shakes
I think you're looking at around $300-$350 for motor mounts. I hope you can get it cheaper buying aftermarket parts.
Without proper garage equipment - very unlikely you can do it yourself. |
RE: Engine Shakes
I would try idling the car up a little bit. Those model accords are bad about doing shaking like that.
