92accordwagon |
11-20-2009 03:43 PM |
well are you sueing the euro h22a and auto? or are you useing your stock auto?
and it doesn't matter what one you use cause theya re the same. size and motor mounts and etc. the stock f22 motor mounts will work. your axles will work the euro h22a and auto tranny are the same as a f22a and auto they are the same size and etc. the hard part is going to be wiring up the motor but thays its everything else is a bolt in swap. i've help my buddy put a h22a auto into is 90 honda lx coupe and it took ups about 8 hours to pull the stock motor/tranny clean up the enghine bay put the new motor/tranny in wire it up and get it running and driveing
