engine swap '90 accord
okay.
I would like to put a h22 in my 90 accord. It has an automatic tranny. I want to be a 5 speed when all is said and over with. What all do i need to be able to pull this off and were do I buy it for the best price? |
RE: engine swap '90 accord
You will need to install a clutch hydraulic system (master and slave cylinders, pedal), gear shift lever and route the two shift cables, and proper transmission mounts.
If you go to www.cb7tuner.com you will find a huge amount of info on the 90-93 accords and your swap in particular, including instructions |
