ENGINES IDs
1st generation accords: 1976-1981 2nd generation accords: 1982-1985 3rd generation accords: 1986-1989 4th generation accords: 1990-1993 5th generation accords: 1994-1997 6th generation accords: 1998-2002 7th generation accords: 2003+ (Trim and equipment levels range from DX, LX, LXi, EX, EX-R, SE, SEi, V-6) -these include canadian models Engine Identification(year/model, engine displacement, engine series, fuel system, engine type) 2nd Gens 1984 Accord: 1.8L(1829cc), ES2, 3bbl, SOHC 12-valve 1985 Accord: 1.8L(1829cc), ES2, 2bbl, SOHC 12-valve 1985 Accord SEi: 1.8L(1829cc), ES3, 2bbl, SOHC 12-valve 3rd Gens 1986 Accord: 2.0L(1955cc), BS, 2bbl, SOHC 12-valve 1986 Accord LXi: 2.0L(1955cc), BT, EFI, SOHC 12-valve 1987 Accord: 2.0L(1955cc), A20A1, 2bbl, SOHC 12-valve 1987 Accord LXi: 2.0L(1955cc), A20A3, EFI, SOHC 12-valve 1988 Accord DX/LX: 2.0L(1955cc), A20A1, 2bbl, SOHC 12-valve 1988 Accord LXi: 2.0L(1955cc), A20A3, EFI, SOHC 12-valve 1989 Accord DX/LX: 2.0L(1955cc), A20A1, 2bbl, SOHC 12-valve 1989 Accord LXi: 2.0L(1955cc), A20A3, EFI, SOHC 12-valve 4th Gens 1990 Accord DX/LX: 2.2L(2156cc), F22A1, MPFI, SOHC 16-valve (single exhaust manifold) 1990 Accord EX: 2.2L(2156cc), F22A4, MPFI, SOHC 16-valve (dual exhaust manifold) 1991 Accord DX/LX: 2.2L(2156cc) F22A1, MPFI, SOHC 16-valve (single exhaust manifold) 1991 Accord EX: 2.2L(2156cc), F22A4, MPFI, SOHC 16-valve (dual exhaust manifold) 1991 Accord SE: 2.2L(2156cc), F22A6, MPFI, SOHC 16-valve (dual intake manifold) 1992 Accord DX/LX: 2.2L(2156cc) F22A1, MPFI, SOHC 16-valve (single exhaust manifold) 1992 Accord EX: 2.2L(2156cc), F22A4, MPFI, SOHC 16-valve (dual exhaust manifold) 1992 Accord EX-R: 2.2L(2156cc), F22A6, MPFI, SOHC 16-valve (dual intake manifold) 1993 Accord DX/LX: 2.2L(2156cc) F22A1, MPFI, SOHC 16-valve (Canadian models: LX/EX) 1993 Accord EX/SE: 2.2L(2156cc), F22A6, MPFI, SOHC 16-valve (Canadian models: EX-R/SE) 5th Gens 1994 Accord EX: 2.2L(2156cc), F22B1, MPFI, SOHC 16-valve (Canadian models: EX-R) 1994 Accord DX/LX: 2.2L(2156cc), F22B2, MPFI, SOHC 16-valve (Canadian models: LX/EX) 1995 Accord EX: 2.2L(2156cc), F22B1, MPFI, SOHC 16-valve (Canadian models: EX-R) 1995 Accord DX/LX: 2.2L(2156cc), F22B2, MPFI, SOHC 16-valve (Canadian models: LX/EX) 1995 Accord V-6: 2.7L(2675cc), C27A4, MPFI, SOHC 24-valve 1996 Accord EX: 2.2L(2156cc), F22B1, MPFI, SOHC 16-valve 1996 Accord DX/LX: 2.2L(2156cc), F22B2, MPFI, SOHC 16-valve 1997 Accord EX: 2.2L(2156cc), F22B1, MPFI, SOHC 16-valve 1997 Accord DX/LX: 2.2L(2156cc), F22B2, MPFI, SOHC 16-valve 1994-1997 DX-LX- 130HP 2.2L I4 non V-tec Ex-Station Wagons 145HP 2.2L I4 V-tec motor V6 .95-97 . 170HP 2.7L cast iron V6 6th generation .. 1998-2001 Sedan comes in DX, LX, LX-V6, EX EX-V6, Accord V6, and the occasional SE Coupe comes in LX, LX-V6, EX, EX-V6, Accord V6 and the occasional SE engines and trannies offered DX: 135HP 2.3L non V-Tec motor. SE, EX and LX: 150HP 2.3L SOHC V-Tec I4. LX-V6 and EX-V6: 200HP 3.0L SOHC V-Tec. All 4Cyl cars: manual standard and auto optional. All V6 cars: 4spd automatic. F20A1 2.0L JDM DOHC non-VTEC 90-93 Accord Si 155hp F20B 2.0L JDM DOHC VTEC 90-93 Accord Si-R 190ps F22B 2.2L USDM SOHC VTEC 94-97 Accord EX/97 2.2CL 145hp F23A5 2.3L USDM SOHC 98+ Accord DX 135hp F23A1 2.3L USDM SOHC VTEC 98+ Accord EX & LX/98-99 2.3CL 150hp F23A4 2.3L USDM SOHC ULEV VTEC 98+ Accord EX & LX 148hp C27?? 2.7L USDM SOHC non-VTEC V6 95-97 Accord V6 170HP J30A1 3.0L USDM SOHC VTEC V6 98-02 Accord V6 200hp |
RE: ENGINES IDs
correction for last entry
6th Gen Accord 1998-2002 7Th Gen 2003-2007(speculation) 2003 DX base motor: 160HP I4 optional motor: NONE LX Base motor: 160HP I4 optional motor: NONE LX-V6 Base motor: 240HP V6 optional motor: NONE EX Base motor: 160HP I4 Optional motor: 240HP V6 2004 Engine choices remains the same 2005 Engine choice remains the same New model added: Accord Hybrid Base motor: 240HP V6 plus 15HP Electric Motor Optional motor: NONE 2006 HP figures revised due to new standards and ECU tweaking to compensate for new standards I4 is now 166HP V6 is now 244HP Hybrid lowered to 253 HP (or 238 for V6 part of power plant- based upon speculation that electric motor remains unchanged at 15hp) DX dropped and replaced with VP (value package) LX gets sunroof replace DX with VP and engine choices remain the same |
RE: ENGINES IDs
2003 - Present Model Accord
I4 2.4 L K24A4 V6 3.0 L J30A4 |
RE: ENGINES IDs
Update
7th Gen: 2003-2005 2.4L K24A4 160/161 (DOHC i-VTEC) 3.0L J30A4 240/212 (SOHC VTEC) 2006-2007 (facelift) 2.4L K24A8 166/160 (DOHC i-VTEC) 3.0L J30A5 244/211 (SOHC VTEC) 8th Gen 2.4L K24Z2 177/161 (DOHC i-VTEC) LX,VP 2.4L K24Z3 190/162 (DOHC i-VTEC) EX 3.5L J35Z2 268/248 (SOHC VTEC) 2.2L JDM/EURO N22A2 140/251 (DOHC i-DTEC) |
RE: ENGINES IDs
i don't see a listing for the F22B5 engine. i've got one in my accord. its a 1994 2.2esi coupe(edm)
RE: ENGINES IDs
I don't even see one on Wikipedia either.... I never even knew about the F22B5 until I googled it.
RE: ENGINES IDs
It is not on the list because JDM/EDM cars are not taken into consideration, there is not all too much info stateside on them, nor on the internet(at least not in english).
RE: ENGINES IDs
"English muthaf****! Do you speak it?!"
Courtesy of Samuel L. Jackson |
RE: ENGINES IDs
I love that movie
RE: ENGINES IDs
YES!
| All times are GMT -5. The time now is 07:15 AM. |
