I moved your post for better attention.
All the AT-equipped Honda/Acura products I've had or seen have AT cooler built into the radiator. ATF flows from trans to radiator fitting on bottom side of radiator and returns via a second fitting to trans. Interupting this flow and dumping to catch basin is how diy ATF replacement is performed. See following link: good luck |
(Post 321830)
All the AT-equipped Honda/Acura products I've had or seen have AT cooler built into the radiator. ATF flows from trans to radiator fitting on bottom side of radiator and returns via a second fitting to trans. Interupting this flow and dumping to catch basin is how diy ATF replacement is performed. See following link: 10 Min Automatic Transmission Fluid Flush + Replacement (Most Cars) - YouTube good luck so the car already has a cooler? |
Yes, car has cooler if there are two ATF lines to the radiator.
good luck |
