f22a6 head with f22b2 block questions
I have a couple of questions. I have a 95 accord with a f22b2 in it. The car had a bad head on it when i got it. I have a f22a6 head i was going to use. I have only two problems i can see.
I have the headgasket and intake gasket for the f22b2 motor. The coolant port on the a6 head does not match the gasket. The hole is round in the head and the gasket it oval. The intake it is round, so can i just get the a6 gasket to fix this? Second, which head gasket do i need, the a6 or the b2? The b2 head has an extra hole right in the middle, and the a6 does not. I looked on the block, and there is just a flat spot there. So i assume the block and gasket just blocks it off. So will i need the a6 head gasket? I just want to make sure this is right. Thanks for everything. |
It sounds like it should work. Are you using a quality gasket like Fel-Pro? I just hope the coolant doesn't push the gasket out over time, it can happen.
