F22b>F22a?
I am feeling really lazy at the moment and don't feel like looking this up. SO can anyone tell me the specs on the F22a and F22b (vtec!) engines i currently have the f22a of course....stock 91 accord LX coupe 5 speed and I can get a F22B really cheap just has an auto trans so was wandering if my F22A tranny would bolt rught up to the F22B....i know i have to remove a center bushing or something of that sort on teh engine (not sure what honda has) that kept the torque converter straight but other then that i was wandering what else id have to do. Thanks for any help. :D
RE: F22b>F22a?
F22B and F22A transmission are interchangeable. What do you mean by specs? the F22B1 makes 145hp.
RE: F22b>F22a?
well my friend here you go specs on the f22a
[ul][*]Bore × Stroke: 85.0 × 95.0 mm[*]Displacement: 2156 cc[*]Valve Configuration: SOHC, 16 valves, Non vtec[*]Compression ratio: 8.8:1[*]Max power: [ul][*]F22A1: 125 hp (93 kW) @ 5200 rpm[*]F22A4: 130 hp (97 kW) @ 5200 rpm[*]F22A6: 140 hp (104 kW) @ 5600 rpm[*]F22A7: 150 hp (110 kW) @ 5900 rpm (147hp/108kW with automatic transmission) [/ul][*]Max torque: [ul][*]F22A1: 137 ft·lbf (186 N m) @ 4000 rpm[*]F22A4: 142 ft·lbf (193 N m) @ 4000 rpm[*]F22A6: 142 ft·lbf (193 N m) @ 4500 rpm[*]F22A7: 145 ft·lbf (198 N m) @ 5000 rpm [/ul][/ul] |
