F23 swap in Gen 5
#41
Engine does run fine. Had to replace wires/plugs and rotor. She struggled for first start up but fires right up now. Valves just need to be adjusted.
I used OBD1 harness and ecu, everything plugs in as if it were an f22 going back in. Ignition was the same. I also used the distributor off my f22 so im not having to have an external coil, or else i would have ran into a problem there with the wiring. Motor mounts do line up exactly the same, no major modifications for fitment.
Aftermarket: F1 6 puck ceramic clutch, AEM CAI, Stainless headers and exhaust. A littler louder than i imagined but i can deal with it for now.
This is a good beginner swap even though nothing changes, you can still atleast get the idea of what you may have to deal with before doing a H/B series swap.
#42
Good to know. If swapping into a VTEC car (internal coil), use the F22's dizzy and the wiring is plug & play.
#43
hey, guys! I thought I would give a few pointers on this build from when I did it. Though on top of the f23a1 swap from My factory f22b1 swap I also did an auto to manual trans swap, I found a few things different. First is that rather than doing the iac wire swap I instead just kept the f22b1 intake with no problems, next I used the factory auto rear mount and had no problems with alignment or any such thing. Bolted right up! The factory f22b1 Thermostat work perfect, and any OBDII Sensors I just switch out With OBDI. Knock Sensor wasn't necessary so I left it as a plug and I even used the factory f22b1 ECU With no problem what so ever, the car Runs GREAT! For the future I plan a new build of the f23, including a Port and Polished f22a6 head, k20a2 pistons, and port and Polished h23 intake. Expected Gains will put me Around 200Hp Easily competing with an h22 with all factory parts and a price tag on the whole car or less than an h22 alone.
#46
Lurch, it's been six years since I did this swap and don't recall the vacuum line routing. And I no longer have the car. But it couldn't have been difficult or I would have mentioned it in the swap thread. Best to take King's advice and compare the F23's vacuum diagram with the F22's and hook up lines and plug holes as necessary.
#47
#48
F23 swap
Hey, can i ask how you did the engine swap exactly? I have a 96 accord and im currently doing this swap and the car just simply won't start. It sounds like it wants to start but it doesn't. I just need some advice, Its my first time doing an engine swap so Im surprised that I got this far.
did you ever figure out why it wouldn’t start I just did the swap and when it started it sounded sluggish almost like it was misfiring and then it cut off I need help
