F23A1 in a 1992 Accord EX?
Hello Everyone :)
I have a chance to pick up an F23A1 motor for $200 F23A1 honda accord motor, running when pulled. 60-70k miles on it, includes complete longblock with dizzy, intake manifold and flywheel.. Thanks much!! |
RE: F23A1 in a 1992 Accord EX?
Even if it doesn't fit it might be worth to buy and fix up and resell it for a higher price... The F23A1 is 6th gen engine you want to put into a 4th gen...
It should fit almost perfectly. You may run into some problems with the driver's side mount though. You'll obviously have to extend and rewire a few things. The biggest will be adapting the IACV on the back of the F23 intake plenum to your car. The F23 uses a 3 wire, yours is a 2 wire. There's obviously going to more things to work out but it shouldn't be that hard of a swap.
