Flywheel weight
What is the weight of a stock f23 flywheel?
RE: Flywheel weight
i think about 15 lbs.
RE: Flywheel weight
I would guess highr than that.
RE: Flywheel weight
I just took it off the scale and it weights 17lbs, I'm trying to see if it would be worth to get a lightweight flywheel 11lbs. I'm not to stick with the stock. Thanks
RE: Flywheel weight
I thought it was around 20 to 30 but 17 isn't bad
RE: Flywheel weight
I have the xact flywheel by ACT (11 pounds I think) and I think it was worth the money. I noticed better engine response and slightly better acceleration.
RE: Flywheel weight
How is your deceleration? Does it slow down quicker too? And when you let off the gas is your speed being maintained or does it go down fast?
RE: Flywheel weight
I really didn't it notice it slow down a whole lot quicker, maybe just a tiny bit quicker.
I start to slow down when I let off the gas, but it's not like hitting the brake. |
RE: Flywheel weight
Will they talked me into getting a chrome moly 11lbs flywheel. But thanks mbo that's what i wanted to know
RE: Flywheel weight
about how much did they charge you?
| All times are GMT -5. The time now is 08:17 AM. |
