fuel filter
hey all. I was interested in changing my fuel filter today to improve gas mileage. The service department clerk said that the filter rarely needs replacing. So I paid about $100 for a fuel system service. When should I change my fuel filter?
RE: fuel filter
I'd probably do it every 90k or so. Not sure what the manual suggests for interval
RE: fuel filter
well ..... I guess that's another thing that I have to do!!!
RE: fuel filter
i would strongly suggest to replace it every 60k miles
there is a write up on our DIY section on HOW TO REPLACE IT.. filter costs about 25 dollars, from dealer |
RE: fuel filter
ORIGINAL: falkore24 well ..... I guess that's another thing that I have to do!!! |
RE: fuel filter
next time I'm underneath, I'll look ...... I thought all had filters!!!!
RE: fuel filter
on your 00 car, the fuel filter is part of the fuel pump, inside the tank,
like 00 Accord said, it is a screen, and supposely lasts forever, if fuel pressure drops , that would be one of the first things i would look at to see if it is plugged .. |
RE: fuel filter
Yea!!! 1 less maintenance item!!!!! My car is running fine, so I'm not going to mess with it. It seems that my tranny is getting a little sloppier with the 1-2 shift when I'm flooring it ..... I "shift" around 6000 rpm's and it still hits the 7000 rpm limiter. I was ripping down the highway with a friend of my sister's and I bounced the 1-2 shift like 4 times ...... now he thinks his '94 MX6 w/ 240HP JDM motor is the same speed as G3. Not a bad run all considering ..... he has a 5 speed and 2 less doors.
